Taramps T-20.2k
1. Product:
Taramps T-20.2k
2. Specs:
- Number of Channels - 01
- Class of Operation - (D)
- Maximum power @ 12.6 VDC - 1 OHM - 20200 WRMS
- Subsonic Filter (Variable) - High Pass - 5Hz to 50Hz (-12dB / 8th)
- Crossover (Variable) - Low Pass - the 5KHz 50Hz (-12dB / 8th)
- Electronic Diagnostics - (LED indicators):
On - (on)
Clipling - (distortion)
Protection - Protection (short)
- Input Sensitivity - 300mV to 6V
- Input Impedance - 20K OHMS
- Frequency Response - 5Hz to 5kHz
- Low Voltage Power Supply - 10,5VDC
- Maximum Power Voltage - 15VDC
- Consumption at Home - 1 Amp.
- Cons. Maximum Musical @ 12,6VDC - 905 Amp.
- Cons. Maximum sinusoidal signal (100Hz) @ 12,6VDC - 1890 Amp.
- Dimensions (WxHxD) - 291 x 56 x 730mm
- Weight - 14Kg
3. Description/Condition:
Pretty good shape. Backplate is kinda wonky because it's not held on with screws. Not beat up by any means. Works like a champ and actually just won a championship at world finals (in a music class no less). Fan might be getting a little noisy.
I have clamped it exactly one time on batts. 8k rising to ~ 3ohms in the low 12's/high 11's on the AMM-1 in "dyno mode". It does big boy power. Note the bolded above. You still need plenty of juice to run this thing. Don't let the size fool you.
4. Price: :
$1,400 shipped.
Trades will be limited on this one because I am only selling to get another TFE. I will entertain them though.
5. Pictures:
Next to an Ampere 10k prototype.
  • 1 month later...
2003 Dodge Ram 1500 - Deep Orange
Build log - Blowthrought with 4 18's http://www.stevemeadedesigns.com/board/topic/122600-4-18s-in-a-dodge-ram-team-sundown-russia/
Sundown Audio SAX125.2 - Sundown PA 10"
Shok-wiring & RCA's
XS Power D6500
Mechman 320A
Sundown Audio Russia
http://sundownaudio....dex.php?/index
http://www.drive2.ru...ram/ram/skillz/ - more about my truck
http://www.youtube.com/user/Gskillz81
Still selling as a now blown unit or would you like this post closed?
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
