Box design for 1 kicker cvr 15
teamace24
Sorry if this is not allowed or something but I haven't logged on for a while now.
I want to do a basic build foGreatlyr my little scion and am looking for a design for 1 15 cvr slot ported to 38hz with 3.5 net volume and 12 to 13 per port area.
My max dimensions are Height 16.5, depth 17.5, wide 37.5.
Anybody can help me with the cutouts and design or if you have an already pre drawn up one from somewhere else?
Greatly appreciated and will post build pics.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Ignore the typo in the middle I'm on my phone. Thanks
Scion xb 06 measured
So here is a suggestion close to your specs, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/4", figure is just an assembly guide, bracing is 1 1/4" wooden dowel rods:
Thank you very much for your time. I rather do only one front baffle, will that change anything? If so can you adjust that please?
Also what port area inches per does this box have.
The box has 48.75 square inches of port area, you can dismiss the dual layer baffle if you really want but doing the bracing shown at least is recommended.
Ok thanks joe everything will be posted when I start on this in a week.
One last question, did I do the math correctly, does that come out to 13.9 inches of port per?
What audible difference would I see in 12 inches per and 14?
Determining port area in terms of sq in per cubic foot of box volume really isn't the best. A more appropriate solution is to think of port area in terms of "X" sub needs "Y" amount of port area at "Z" tuning regardless of how big or small the box is.
In your situation JoeX disigned your box with the proper amount of port area you will need. There are formulas for determining what that number should be. You can see one here: http://www.carstereo.com/help/Articles.cfm?id=31
What will happen if your port area is inadequate is you can get port noise, which is annoying, or port compression, which will decrease output.
Builds:
Thanks for the info and I'm looking forward to the build.
Thanks joe as well.
  • Who's Online   0 Members, 0 Anonymous, 1653 Guests (See full list)
