Box design for 1 kicker cvr 15
teamace24
Also on the picture of the L port I noticed that the piece that bends its written as 2 3/8 inches but on the graphic it looks like its almost as much as the 10 inch beginning piece of the L.
Is that just the picture or does that piece supposed to go in longer than 2 3/8?
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Yes, the figure is only meant to show you how to assemble the box, how pieces in the cutsheet fit together, this is why I underlined " , figure is just an assembly guide, " above.
Also that small difference in port area won't make it worse in any way, is just 3 square inches of port area more than a 13 sqin/cube you wanted, if any difference you were to notice, that would be better port output when playing full tilt, no difference at lower power, pretty high tuning you did choose though, hope you have tested this is your preferred tuning.
Any other questions or changes let me know.
I actually built a previous box using help from you years ago.
I tuned to 34hz and it played very well but after emailing kicker and always getting a response that I should tune to 40hz, I decided to give it a try since most of rap and other music I listen too doesn't go that low.
I'm sure this box will still hit the 32hz note well which is where my epicenter filters at. Thank you.
  • Who's Online   1 Member, 0 Anonymous, 4924 Guests (See full list)
