Phaeton Posted November 24, 2014 Report Posted November 24, 2014 That would be very cool if they did I could really get use to the ideal of 4 15in svc 4ohm running at 1ohm I really just dont like running amps below 1 for every day pound not a lot of people on here think running under 1 ohm is a good idea, but honestly if you do it right it should be fine. But the real problem is "doing it right" 1997 subaru legacy outback Four 15's in a almost wall Rockford Fosgate t2500-1bdcp Rockford Fosgate T400-4 on tweets Rockford Fosgate T400-4 on highs Rockford Fosgate T400-2 on midrange Rockford Fosgate T400-2 on midbass Optima Yellow top batteries 270A Singer alt (working on a bracket for a second) Lots of Second Skin
alaskanzx5 Posted November 24, 2014 Report Posted November 24, 2014 To run below 1 ohm the right way it would take an amp that is designed to do so. With today's knowledge of speakers a svc sub is just as versatile as a dvc sub Want 1ohm with 1 sub? Buy a svc 1ohm sub Want 1 ohm with 2? Buy 2 2ohm subs For sq guys Want to run 4ohms to 2 Subs? Buy 2 svc 2ohm subs. t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
