jrussell9109 Posted December 3, 2014 Report Posted December 3, 2014 Would like soebody to design a box on a program for a DC XL 12" Calls for 1.5³ ft in a ported box. Edit- Whats a good tune for this 34hz?
Joe X Posted December 3, 2014 Report Posted December 3, 2014 Tuning depends on musical preference and vehicle. 33-35 usually ok. list amp, vehicle models and max dims for a box if you'd like further help.
jrussell9109 Posted December 3, 2014 Author Report Posted December 3, 2014 Tuning depends on musical preference and vehicle. 33-35 usually ok. list amp, vehicle models and max dims for a box if you'd like further help. 15D x 18H x 36W max dimmensions, I listen to mostly rap and some rock. Amp is still undecided, either a Skar 2000.1D, Ampere Audio 2000.1, or a DC Audio 2.0k, The car is a 2000 Ford Focus ZX3 hatchback.
Joe X Posted December 3, 2014 Report Posted December 3, 2014 So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/2", figure is just an assembly guide: The 45 o the back left side is not to be done, others done as follows:
jrussell9109 Posted December 3, 2014 Author Report Posted December 3, 2014 Thanks man, what would you recommend for building this box? 3/4 mdf board?? Subsonic would be set to 24 instead of 28 right?
Joe X Posted December 3, 2014 Report Posted December 3, 2014 3/4 MDF is cost effective and does the job but if you want to spend extra in birch or other stuff, that will also work, on the subsonic filter, the standard rule is half an octave below tuning, that would be 25.5Hz but if you are not playing below 25Hz a 28 Hz setting will do, don't worry too much about the exact frequency, you'll find out what works best for you at setup time, I just like to remind people not to leave the sub unprotected.
alaskanzx5 Posted December 7, 2014 Report Posted December 7, 2014 These cars do best Sub up port back Sub up port to side Sub up port up Sub and port back seems to rattle more and on a meter I can testify lowers output. The trunk dimensions are roughly 30" bottom depth 40" width 20" high 16-17" top depth t1500bdcp 2 t2d4 15" 1 t600.4 1 t400.2 1 set p1 tweets singer alt, tons of wiring, smd vm-1, 80prs, back seat delete, still in the works, aiming for a 145-147 with the ability to play 25hz up to 50hz.
Joe X Posted December 7, 2014 Report Posted December 7, 2014 The above can be set firing everything up if he found it to be better but box is low depth so there should be ample clearance.
