Do lower frequencies draw more amps?
What I'm wondering is, does it take more power to hit lower frequencies 30ish and below? I can go full tilt while driving to some dubstep (40hz and up usually) and never see below high 13s, throw on something that gets lower and I'm looking at low 12s..
'97 Explorer
2 Sundown SA 15's
SQ 2200D
Kinetik KHC1800 (Front)
Kinetik KHC 2000 (Back)
KnuKonceptz 1/0 OFC
130A Alt + Big 3
Oh wow!Do you know what causes that? Does box tuning factor into it?
'97 Explorer
2 Sundown SA 15's
SQ 2200D
KnuKonceptz 1/0 OFC
130A Alt + Big 3
Yea i was gonna say my voltage suffers on high notes. ..
I think it has something to do with the caps in the amp or something. ..
Capacitive reactance = 1/ 2pi * freq * capacitance
So as frequency climbs the reactive gets smaller, as it approaches zero it acts like a short drawing the most power..
But then again idk lol.
It high notes for me tho. In every build.
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Yeah I can handle higher notes with really no drop at all while driving but the second I start in on something low I'm down into battery voltage..
'97 Explorer
2 Sundown SA 15's
SQ 2200D
KnuKonceptz 1/0 OFC
130A Alt + Big 3
it varies quite a bit due to fluctuation in your impedance curve
in a given install your impedance will not stay constant on different frequency
and this is why wiring low on music is a bad idea :)
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
My voltage suffers most on high notes and I notice that if I play a song that goes lower//higher than the audible range of the subs then it does almost nothing to my voltage even if the subs are still moving. Like if I play a 24Hz note with the subsonic filter off it does not effect my voltage because my subs are audible only from 28Hz to 72Hz; but it still is flapping away at almost full excursion.
YouTube: https://www.youtube.com/user/JeepAndBass
Website: https://www.jeepandbass.com/
My Jeep: 157.3dB @26hz Drag Style 162.3dB @36Hz Outlaw 160.7db @35hz Headrest
My Honda: 155.4dB Drag Style 158.0db Outlaw
So if I was wired higher, let's just say I only had one of my 15s and wired it to 2 ohm theoretically I would have less impedance rise and a more "constant level of power"?
'97 Explorer
2 Sundown SA 15's
SQ 2200D
KnuKonceptz 1/0 OFC
130A Alt + Big 3
no your impedance rise would be close (different amounts of power can cause different impedance fluctuation) to the same
think of it this way... at 32 hz you're rising from .5 to 2ohm and at 45hz you could be rising from .5 to 1.3
make sense?
power: dd m4
Mmm I must be doing something wrong then, I have voltage drop like no other in the 20s.. No point in me even trying anything under 28hz because of the drop..
'97 Explorer
2 Sundown SA 15's
SQ 2200D
KnuKonceptz 1/0 OFC
130A Alt + Big 3
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
