What Causes Clipping ? MP3 Quality
Dragonware
Guy takes forever, but thats the basic way which works for most stuff before you have to start manually playing with wave forms and such. He also goes a bit further with the multiple tracks but it was either that link or an old guy..
Hammerdown... 1%
Lol
He didn't do shit to the track
All he did was make the wave smaller
That's the same as instead of listening at volume 30 now you listen to at volume 29
and all the read that showed up might not be a clip signal. It's just higher than 0db and just cause it's higher than 0db doesn't mean it's clipped
Its clipped when processed by your head unit/mp3 player/whatever you are using to play, which is as bad as a square wave as it is essentially the same effect in the end.
As to the lessened volume - No shit sherlock, that is the best way to reduce source clipping on a poorly mastered source which is what we are dealing with in this thread. We are not dealing with professionally mastered audio here (not to say professional audio is very well done these days with all the loudness increasing happening).
Also, there happens to be a handy tool which uses interpolation to reconstruct the wave forms of more destructive clipping. Its not perfect and you're going to bitch about it because you like to complain more than offer help or constructive criticism, but here is anyways as the OP might find it helps him: http://manual.audacityteam.org/o/man/clip_fix.html
You still need to use normalization and track amplification to use Clip Fix properly btw.
Hammerdown... 1%
Why go though all that trouble when you can do it at the head unit by just turning the knob a click to the left
And actually I have
That's a horrible "example" to unclip a song
Cause
You can't unclip a song
Do you know the source of the clip?
Was it an instrument?
Or how it's was recorded?
A sample?
Mixing?
Mastering?
Vocals?
Sometimes a lil clip from the instrument gives a sound that it was intended to be their?
That video doesn't do what it says.
But the bigger problem is why does everyone care?
Clipping never killed anything, overpowering does.
If you've ever looked at the waves of some electronic music and rock you'll notice a lot of squared of waves.
Noelito
Because one click isnt always enough and as the OP has already stated he has knobs that seem to like to travel.
Thats good that you have turned the volume down. Gold star for progressive participation!
You can unclip a song. Its not a perfect method and isnt meant to be perfect, only to work well enough for the average user since we're not all owners of professional studios.
The source of the clip, how it was recorded, samples, mixing, mastering, or vocals dont matter if the resulting output quality from the creator of the content is the issue. The methods i've posted are to reduce damaging levels of clipping and loudness, which the OP is dealing with, thats all.
Yes, distortion is sometimes meant to be in the content to create the desired audio. If you place your audio above the dynamic levels of the equipment that will be playing it back you lose the intended effects.
Kirill - Your entire argument was invalidated the moment you typed "Clipping never killed anything".
Hammerdown... 1%
Thanks for all the help guys, Recones from PSI arrive today Xmas is early.
My Build log :
http://www.stevemeadedesigns.com/board/topic/170934-dragonmobile-re-audio-2300rms-stealth-build-08-focus/
Current System
2020 Ford F-150 XLT Supercrew
Audio Control Epicenter
Audio Control LC7i
Taramp PRO 2.6 DSP
Taramp DS4x800 - Highs
Taramp HD3000.1  Mids
Taramp MD5000.1 Bass
8 x DS18 6.5 Pro x6m - mids
2 x Soundsteam SST-05 Bullet Tweeter
2 x DS18 TW220 Super Tweeters
4 X SkarAudio EVL-8  BASS
Big 3
Yellow Top
Noelito
Why is that? Because 99.9% of the people believe it does?
Overpowering doesn't equal clipping, clipping in car audio usually means overpowering, but not the other way around
You can unclip a song, but it requires reshaping the soundwave and is a pain in the ass to do unless it's just one tiny spot in the track. otherwise you're just wasting your time.
EP95 - Which is where the "clip fix" tool comes in handy as it does the sound wave interpolation for you. I agree that with poor source audio its "kind of pointless" but that may just be due to our tastes. To the OP the audio with messy levels was ok.. so maybe for him its worth it.
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1883 Guests (See full list)
