magillaru Posted December 20, 2014 Report Posted December 20, 2014 Just want to make sure this is right before I start drilling holes in my box..... I want to use a setup that will allow me to wire down/up need be without removing the subs. If I put 4 bolts per sub (8 total) through the box and run each terminal from the sub to the bolt and then configure the wiring outside the box, is this how I would do it? Singer Alternators Team Asshole #anothershittysingerbuild
Skater229 Posted December 20, 2014 Report Posted December 20, 2014 http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
magillaru Posted December 20, 2014 Author Report Posted December 20, 2014 I understand that......I'm just wondering if it's fine to basically extend the sub terminals to the bolts and essentially wire for whatever impedance I want to run outside the box? I've seen some builds where it looks like this is how it was done but I want to be sure.... Thanks! Btw, nice build man, looks sweet! Singer Alternators Team Asshole #anothershittysingerbuild
Skater229 Posted December 20, 2014 Report Posted December 20, 2014 Yea that is fine, but your math was just wrong... and that link is a great place for wiring info... 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
magillaru Posted December 20, 2014 Author Report Posted December 20, 2014 The diagram I posted was series/parallel, no? If it's not, now I'm confused..... Singer Alternators Team Asshole #anothershittysingerbuild
Skater229 Posted December 20, 2014 Report Posted December 20, 2014 That is correct... it is... Two DVC 2ohm subs in a Ser/Par config will be 2ohms total... Two DVC 2ohm in a Parallel will be .5ohms 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
magillaru Posted December 20, 2014 Author Report Posted December 20, 2014 I was taking this into consideration haha Thanks man! Appreciate the help! Singer Alternators Team Asshole #anothershittysingerbuild
Skater229 Posted December 20, 2014 Report Posted December 20, 2014 No problem, and good luck with the system... 2010 Chevy HHR Panel (Work in progress) Pioneer AVHX-5800BHS McLaren MLM880's and MLT2's 2ea per door on a DC 175.4 Two DC Audio M4 Level 5 15's On A DC5K Alt CES 200/270+ 4ea Banks of Maxwell 2.7v 3000f caps for a total of 2000f 1ea XS 3100 and 2ea NSB FT170 Batts for 450+ah Not a HUGE build but here it is... DC Audio HHR Build
