Need a little help with speaker wiring configuration....
Just want to make sure this is right before I start drilling holes in my box.....
I want to use a setup that will allow me to wire down/up need be without removing the subs.
If I put 4 bolts per sub (8 total) through the box and run each terminal from the sub to the bolt and then configure the wiring outside the box, is this how I would do it?
F693FF82-C015-44E0-965E-8AB460FB70D0_zps
Singer Alternators
Team Asshole
#anothershittysingerbuild
Pioneer AVHX-5800BHS
Alt CES 200/270+
I understand that......I'm just wondering if it's fine to basically extend the sub terminals to the bolts and essentially wire for whatever impedance I want to run outside the box?
I've seen some builds where it looks like this is how it was done but I want to be sure....
Thanks!
Btw, nice build man, looks sweet!
Singer Alternators
Team Asshole
Yea that is fine, but your math was just wrong... and that link is a great place for wiring info...
Alt CES 200/270+
That is correct... it is...
Two DVC 2ohm subs in a Ser/Par config will be 2ohms total...
Two DVC 2ohm in a Parallel will be .5ohms
Alt CES 200/270+
No problem, and good luck with the system...
Alt CES 200/270+
  • Who's Online   1 Member, 0 Anonymous, 1219 Guests (See full list)
