Guest Posted December 28, 2014 Report Posted December 28, 2014 So I am looking to get a pair of these. http://www.droppinhzcaraudio.com/toolmaker-sae-top-post-4-lug-style-battery-terminals/ I want to know the diameter of the bolts. I want to be able to fit zero gauge terminals on them as well as smaller gauge terminals for the stock power/ground wires. And since I will be doing the big 3 upgrade, I am likely going to just ground the alt to the chassis directly instead of routing it to the battery negative. If this is the case, I think I will only need a single positive toolmaker terminal as the negative post will only have one zero gauge ground and possibly the factory ground as well.
Rich Schenk Posted December 28, 2014 Report Posted December 28, 2014 Not sure try hitting up Cody at droppinhz.com ask him or tm on fb. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Kyblack76 Posted December 28, 2014 Report Posted December 28, 2014 So I am looking to get a pair of these. http://www.droppinhzcaraudio.com/toolmaker-sae-top-post-4-lug-style-battery-terminals/ I want to know the diameter of the bolts. I want to be able to fit zero gauge terminals on them as well as smaller gauge terminals for the stock power/ground wires. And since I will be doing the big 3 upgrade, I am likely going to just ground the alt to the chassis directly instead of routing it to the battery negative. If this is the case, I think I will only need a single positive toolmaker terminal as the negative post will only have one zero gauge ground and possibly the factory ground as well. lol.. just change the eyelet ????? if your stock wire is whatever.. put a eyelet that will fit... its not rocket science.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Guest Posted December 28, 2014 Report Posted December 28, 2014 So I am looking to get a pair of these. http://www.droppinhzcaraudio.com/toolmaker-sae-top-post-4-lug-style-battery-terminals/ I want to know the diameter of the bolts. I want to be able to fit zero gauge terminals on them as well as smaller gauge terminals for the stock power/ground wires. And since I will be doing the big 3 upgrade, I am likely going to just ground the alt to the chassis directly instead of routing it to the battery negative. If this is the case, I think I will only need a single positive toolmaker terminal as the negative post will only have one zero gauge ground and possibly the factory ground as well. lol.. just change the eyelet ????? if your stock wire is whatever.. put a eyelet that will fit... its not rocket science.... I understand what you are saying but is it easy to find a small gauge ring terminal like 8 or 10 gauge that has a zero gauge size eyelet? I do not know what I could buy that.
Kyblack76 Posted December 28, 2014 Report Posted December 28, 2014 No offence.. but my god...... you guys that buy at some places, ... .. jesus.. do you want them to build the damn thing for you ?? my hell.... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Guest Posted December 28, 2014 Report Posted December 28, 2014 No offence.. but my god...... you guys that buy at some places, ... .. jesus.. do you want them to build the damn thing for you ?? my hell.... I guess I do not understand your frustration. I am trying to do a nice build for the first time. I am just trying to make sure I do not do something stupid.
jrath Posted December 28, 2014 Report Posted December 28, 2014 First, buy the Toolmaker battery terminal. Second, measure the bolt size. I would guess it is either 5/16 or 3/4. Third, buy ring terminals with the appropriate size opening. It is very easy to find 1/0, 4, and 8 gauge ring terminals with this size opening. ***Straight forward question with a straight forward answer.
