Bump4life's New Benz **Updated 5/13/15. lowered and ipad dash installed!**
in case you missed it cause its out of order, these are the FINAL plots and spec
of what you are about to witness.
ported (green) vs 6th (blue)
6th alone. that car resonanceat 40hz gunna help the dip in output for the 6th.
rear chamber
front chamber.
OK
NOW ON WITH IT!!
cut that salvaged wood.
it is winter in michigan. cold in all these pics. DEVOTED.
basic shape
done. but look at that finish doe. :(
sub
low port
high port
low port
assembly
baffle test fit
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
laying out
hole time
gunna be a tight fit on the baffle
making the 6 inch aero.
6 inch ID and 7 inch OD
ports
routed
backside routed
perfect fitment
BMW M340 xDrive
gluing
NO FLEX ZONE.
glassing it in
mixing it hot. it was like 15 degrees when I did it. so hot it was smokin
BMW M340 xDrive
and its in
cutting final routes
Designed to accomadate even the deepest 10! so if any of you want this design, it should fit most 10 inch woofers!!
BMW M340 xDrive
I was pretty confused how this was going to work until you put up the pics of the wooden port venting outside the box.
2008 Subaru WRX STI
K&N Typhoon Intake
Invidia Polished Stainless 3" turbo back with cat
Cobb Accessport
Dyno tune from Kaizen Tuning
320awhp 330ft-lb awtq
MTX 421D Sub amp
American Bass SQ900 Highs/Mids amp
Sundown Audio SD-2 10 D4
JL Audio XR653-CS 3-way Components
3sixty.2
Second Skin Damplifier Pro
Custom fiberglass wheel well enclosure
Transmission Line quasi-floor enclosure
http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/
Bill Fitzmaurice TLAH line-array hifi towers
9 Goldwood 4" mids (each)
12 Goldwood 1/2" tweeters (each)
NAD 1020 Preamp
MiniDSP 2x4 Balanced processor
Thorens TD166mkII Turntable
Hafler DH-200 Amplifier
http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/
https://www.facebook.com/HolyMountainGlass
since i reused the wood, the surface wasnt great. gunna carpet.
BMW M340 xDrive
Nice looking port so far
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
me to! I'm looking at it like wtf? then it all clicked!
a dd z on a few k.. in.a 6th..... I'd screw with kids i give demos to. tell them it's a mtx 5500 on 600w
be like "it's all in the box bruh" haha
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
new deck (thinking 80 prs, or flip out)
This build just made me want one of those ports
oh lawd.
Screw that weather.
That is all.
Tuned in for the SQL doors. Let's see if you can top my sound stage ;)
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
