How Much is Enough? Alertnator output that is...
I currently have in an 06 envoy 4.2l i6
Big 3 in 1/0 ofc
2 XS d3400(1 run 1/0 pos and neg from front to back)
mechman 250a alt
DC 3.5K
1 DC XLM2 15 d2
zapco ref 750 and 350
About 20-30 seconds into a heavy song(with full charge on batts) i get voltage drop to 12-13ish volts and the amp starts to clip. Then the coil smells a bit. If i tune it not to clip it just isnt loud enough.
Should this amp on this electrical be enough to smack this sub around? The more i lean on it the louder it gets, even when driven to clip it gets louder. So the sub isnt near reaching its limits on a power level when the amp is tuned properly.
Do i need more batteries? Bigger amp? Bigger alt(biggest direct fit is a singer 350)
would hate to throw in a 5k and wind up in the same boat due to electrical starvation as that amp should make that sub cry inside.....
And can any of you machine heads make me a dual alt bracket? Would love to dedicate one alt to the sub amp @ 18v... PM me....
I feel as if you have enough electrical to handle it...
Also, 12-13 is acceptable voltage in most people's books
Are you sure your amp is tuned right? Deck tuned right? Are you trying to ask too much from your setup?
Nope. I have no idea what i need to run at 18v, other than another alternator. What is the most you guys think that 250a alt can handle sub amp wise? I can fit up to 4 total batteries in my current build, and i can still upgrade to a 350a alt, but thats the biggest anyone will make for my truck. Just trying to survey my options here
I think your alt is fine your battery reserve leaves a lot to be desired
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 4212 Guests (See full list)
