2011 Honda Accord Sedan(Slow Budget Build)
Should be fine I would just recommend mounting the amplifier itself to a board first then mount the board to the frame/metal or whatever your mounting it to in the car
Alright , today redid my kick speaker boxes. I already had the boxes laying around which housed 6x9's originally so I simply put a 6 inch baffle over the existing 6x9 hole.
BLUE LED'S were also added to the speaker grills
Never understood why PRV Gives 3 wattage ratings?
Yes very ugly indeed lol Its sealed with heavy duty wood glue and sealant. I'ts air tight tho.
LED strip placed on backside of speaker grill
Black carpet to cove imperfections lol
LED wiring and 14 gauge speaker wire. Polyfill added also. (((Don't mind the terminals i changed them out)))
Wiring up LED strip for speaker grill
New vs old
Clean
Test fitting
Light testing
Next updates are as followed
:AMPLIFIER REPAINT
:FINISH AMPLIFIER RACK BEHIND REAR SEAT
:SUBWOOFER BOX REBUILD
:HEADUNIT REWIRING
  • 3 weeks later...
Been a minute...but today I just brought some head rest monitors and a new deck for the accord.
The thing I like most about the deck is that it comes with a 13 Band EQ. Also lots of other octave controls, so that I can fine tune the system.
~PIONEER AVH-x1700s
~(2) 9" GRAVITY LCD monitors
Depending on how i'm feelin i'll probably wire it tommorrow.
  • 3 weeks later...
Alright so basicly I will be redoing the whole system. It still will be an overkill with mid and highs but this time around the speakers will now be playing only specific frequency ranges. I will clarify what I mean by showing a quick chart were I will be crossing over the speakers. I will also be rebuilding my trunk . The stock gray carpet will be overlapped with new jet black carpet . The tiny Pre-fab box that I have will also be replaced with a custom box that I am working on at the moment. I have a couple of pics of that also. The new system will have 4 Amps instead of the 3 and I will be tossing out the 4 band eq since theres really no need for it anymore since I have the new PIONEER AVH-X1700DVD HEAD UNIT, (13band eq + crossovers).
((((NOTE))))) dont worry about the spl I just wanted to show crossover points.
Decent subs even tho most dont like kicker subs
Not sure if I wanna do 4 or 6 MID BASS speakers yet. 4 up front 2 in the rear shelf not sure yet. But there will be 1 MID-RANGE in each door.
As for the BULLETS/DOME TWEETS There will be 1 of each in each door. I will double post pictures of the new custom box I started for the SUBS.
For the SUB box I decided to tune to 35 Hertz and make the box much bigger than the Pre-Fab box
External Dimensions - 30"x13"x26"
Internal Dimensions - 28.5"x11.5"x24.5"
Volume - 4.6 Cubes
Volume after woofer and port Displacement - About 4.2 Cubes
Tuning - 35 HERTZ
Port assembled
Test fitting port
Time to double baffle
I know i know i need clamps
Stock 6x9 for size comparison .Tomorrow I will work on it some more and get some more pics up.
What are the dimensions of your port?
Looks good so far nice progress in ability. One thing I would do is get black carpet like from Pep boys the thick stuff and where the OSB is showing carpet over it. It will take some skill but the end result is bad ass. http://i1260.photobucket.com/albums/ii561/Jeffrey_Small/IMAG1363_zpsc1c6f818.jpg As in this pic OSB splinters suck ass trust me. If you lept the scraps you can trace it out even easier.
Old set up..
2003 PTGT 350WHP .. Sold
Orion 600.2
ED 16ov.2
MTX 4205
Focal Pollyglass
Clarion VZ309
New
2005 Subaru Legacy Wagon.
Audio:
Pioneer X5500 Source
Pioneer D1720 Front stage running of a Elemental Designs NINe.2
Hifonics BRX 1600.1D running a Obsidian 12 v3 1.1 cf sealed
Performance:
Custom tune
Home Security specialist.
CCTV installer.
Not enough port area
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
I use Winisd they say its not accurate but it works fine when I use it I've made 7 boxes and they all came out fine. How big you suggest for the port? @Evnldr I will be re-building that crap also. I will be using mdf this time. I just wanted something quick the first time.But yes the whole trunk will be black carpet. Parts express has a real good deal on black carpet.
OK so today I finished up putting together the box. I also made a rookie mistake that really pissed me off. Im not going to tell you what I did wrong but you should be able to see what I did wrong. LOL Lets see who all catch the mistake. I also brought some 12+16 GAUGE speaker wire from a wholesale speaker warehouse and made some MID-RANGE and BULLET TWEETER pods for my front doors.
Me lol
The rookie mistake
Thick baffle
The 12 gauge
The 16 gauge
The front door MID-RANGE pods
