2011 Honda Accord Sedan(Slow Budget Build)
Are those wires soldered or what?
Those aren't crimp terminals and then I see strands exposed from the ring terminals so you got me kind of worried man.
So how did you secure the terminals to the wires?
It absolutely does not work
1. Those are not crimp terminals
2. Even if they were vice grips dont exert enough force to crimp the wire properly.
you need to take them off and redo them.
Also Ghetto crimps, snowdrifter should be here soon.
Unless you're going to buy real crimpers just use the terminals you have and solder them properly.
Ive never had a problem or voltage issues from crimping those type of ring terminals so to each their own. Now could soldering be the best method, sure and thats with any terminal. Just my .02
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Lol. They are not crimp terminals the only thing you are doing is squeezing it around the wire, a proper crimp tool and terminals will form a cold weld.
I'd like to see you do that with those terminals and some vice grips or pliers.
