YukonDCXL Posted January 2, 2015 Report Share Posted January 2, 2015 Set subs to -10 or I like snows -7.5db. Some play it safer and go -5. Up to you and your system Link to comment Share on other sites More sharing options...
Noel989 Posted January 2, 2015 Report Share Posted January 2, 2015 If you only go to 50 then set your amp gains at level 50 on your hu... It would make know since to set at 56 if you never go there... You wont actually be set to that distortion point, you will be way under and not get the full potential out of the amp. Why won't he? His gain will just be a bit higher since he has compensate for having less signal/voltage going into the amp Build Log - http://www.stevemead...-cruiser-el-pt/ Link to comment Share on other sites More sharing options...
YukonDCXL Posted January 2, 2015 Report Share Posted January 2, 2015 I mean you wont acually be set to distortion point at level 50 if you tune a level 56. You need to tune amp gains at the max undistorted volume and or the max volume you intend on using. So if you play your system full tilt at 50 out of 57 then to at 50. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted January 2, 2015 Report Share Posted January 2, 2015 What is the reason to not use 56 though? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
Jessica Posted January 2, 2015 Report Share Posted January 2, 2015 What is the reason to not use 56 though? thats what i said. lol more info is needed. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
YukonDCXL Posted January 2, 2015 Report Share Posted January 2, 2015 Oh I dont know his reason for that. I go a couple notches below what my dd1 says I distort at just to be safe Link to comment Share on other sites More sharing options...
Jessica Posted January 2, 2015 Report Share Posted January 2, 2015 Oh I dont know his reason for that. I go a couple notches below what my dd1 says I distort at just to be safe why use the tool if you dont trust it? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
GorillaFIngeRs Posted January 3, 2015 Author Report Share Posted January 3, 2015 Only reason I would only go to 50 is because my stock highs and mids sound like shit after about 51. I already set it up though. I went with -10db. I set the system up at 55 since my head unit actually distorted at 56. Definitely gained some responsiveness and output, this alpine is now alive! Played it pretty hard for a decent amount of time and have no heat on the cone, amp still nice and cool! I'm excited to be able to roll around without worrying about the sub now. SMD is the shit for this tool! Seriously. AQ3500.115" Fi SP41/0 Knuconceptz Power/Ground 1/0 Sky High Big 3 UpgradePioneer AVH-4200NEXXS Power D1200 Underhood Intimidator Gel In Trunk CES 250A Alternator Link to comment Share on other sites More sharing options...
YukonDCXL Posted January 3, 2015 Report Share Posted January 3, 2015 Oh I dont know his reason for that. I go a couple notches below what my dd1 says I distort at just to be safe why use the tool if you dont trust it? Because it actually says my hu does not clip and I dont believe it because at full volume set amps gains and subs vc would heat up and smell. tuned amp with hu a coulple clicks below full volume and I have no issues with vc's over heating now.... Idk may have been somehting I was doing wrong that it was sensing distortion Link to comment Share on other sites More sharing options...
