fordbassmaker95 Posted January 4, 2015 Report Posted January 4, 2015 I was wondering if I did two runs of cca would my voltage be as good as using ofc wire??
Phaeton Posted January 4, 2015 Report Posted January 4, 2015 yes, but you should spend the few extra dollars and get two runs of ofc! much better than cca wire. 1997 subaru legacy outback Four 15's in a almost wall Rockford Fosgate t2500-1bdcp Rockford Fosgate T400-4 on tweets Rockford Fosgate T400-4 on highs Rockford Fosgate T400-2 on midrange Rockford Fosgate T400-2 on midbass Optima Yellow top batteries 270A Singer alt (working on a bracket for a second) Lots of Second Skin
islandpride684 Posted January 4, 2015 Report Posted January 4, 2015 What you plan on running? Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
LT.Smoke Posted January 4, 2015 Report Posted January 4, 2015 Closed... Has the happenings of becoming a versus thread... OP either type of wire will suffice. Plenty of people run cca with good results...Plenty run ofc with good results Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
