gage120 Posted January 7, 2015 Report Posted January 7, 2015 I have a sundown sa-12 with a 32hz 2 cubic foot box and a 3000 watts ssl mono block amplifier wired at 4 ohms and is supposed to be putting 1100 watts but the sub isnt loud at all my e-12 was louder the sa gets lower but not loud at all someone please help
Miguels Posted January 7, 2015 Report Posted January 7, 2015 what was the other sub wired to? my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Jeff4661 Posted January 7, 2015 Report Posted January 7, 2015 Did u use the same box for the e-12? Current build 05 Yukon SLT http://www.stevemeadedesigns.com/board/topic/195350-jeffs-05-yukong-wall-build/
Cj Kumz Posted January 7, 2015 Report Posted January 7, 2015 Post what setup you had on the e12. Like box size, tuning, amp, load to amp. Even the sub and port positions. Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
philrab Posted January 7, 2015 Report Posted January 7, 2015 Same box? What was the E12 tuned to? I'm in a similar box albeit on less power (2.15 cubes tuned to 33hz.) My sub stage is definitely biased to low notes, but it still bangs. 1100 watts should be enough to get that SA12 moving. Also, have you tried reversing the speaker leads? Perhaps you're 180 degrees out of phase, that would definitely cause it to not be as loud as it should be. 2015 Toyota Tacoma Build Thread 2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount. Build Thread 1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers. 1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 I used a different box for my e-12 it was a lot smaller I had my wires wrong 2 nites ago I had the positive on the negative and negative on the positive I fixed it and didn't notice a difference
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 what was the other sub wired to? A 760 watt 2 channel pioneer
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 Same box? What was the E12 tuned to? I'm in a similar box albeit on less power (2.15 cubes tuned to 33hz.) My sub stage is definitely biased to low notes, but it still bangs. 1100 watts should be enough to get that SA12 moving. Also, have you tried reversing the speaker leads? Perhaps you're 180 degrees out of phase, that would definitely cause it to not be as loud as it should be. I had it wired wrong and I fixed it and nothing happened
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 Post what setup you had on the e12. Like box size, tuning, amp, load to amp. Even the sub and port positions. TO be honest I don't know all that stuff
Joe X Posted January 7, 2015 Report Posted January 7, 2015 Post what setup you had on the e12. Like box size, tuning, amp, load to amp. Even the sub and port positions. TO be honest I don't know all that stuff So what changed from your e 12 setup, what vehicle you are using now and some pics of the current box if possible.
