gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 Post what setup you had on the e12. Like box size, tuning, amp, load to amp. Even the sub and port positions.TO be honest I don't know all that stuff So what changed from your e 12 setup, what vehicle you are using now and some pics of the current box if possible. I can't get pictures now but my e 12 box is like half as big as my sa 12 its in the same car. I literally changed everything from my e-12 I got a new box new amp new wires so like everything changed
Miguels Posted January 7, 2015 Report Posted January 7, 2015 I had it happen to me.1 coil was out of phase when I wired the sub.. Another thing is you're wired at 4 ohms and Country be rising to 16 ohms. Impedance rise is a Bitch my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 I had it happen to me.1 coil was out of phase when I wired the sub.. Another thing is you're wired at 4 ohms and Country be rising to 16 ohms. Impedance rise is a BitchCan you explain that last part please. I can wire my sub to 1 ohm I just dont want to blow it
Joe X Posted January 7, 2015 Report Posted January 7, 2015 I can't get pictures now but my e 12 box is like half as big as my sa 12 its in the same car. I literally changed everything from my e-12 I got a new box new amp new wires so like everything changed An E 12 box should be about the same size as a SA-12 box, the SA-12 will need greater port area but that would not change the box size that much so you may want to take measurements of your current box (inside and out), or a sketch if you have one and mention vehicle and amp models, also as stated above check again all your wiring just to make sure.
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 I can't get pictures now but my e 12 box is like half as big as my sa 12 its in the same car. I literally changed everything from my e-12 I got a new box new amp new wires so like everything changed An E 12 box should be about the same size as a SA-12 box, the SA-12 will need greater port area but that would not change the box size that much so you may want to take measurements of your current box (inside and out), or a sketch if you have one and mention vehicle and amp models, also as stated above check again all your wiring just to make sure. Ill put pictures of both of them up today
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 Sub coils wired like this: There not right now. But I can change it
gage120 Posted January 7, 2015 Author Report Posted January 7, 2015 So I should change to 1ohm? I feel like I will blow it.
Miguels Posted January 7, 2015 Report Posted January 7, 2015 What amp do you have? Are you sure it does rated.. 3000 watts on a good amp is not the same as 3000 watts on a boss amp or the like boss amps my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Miguels Posted January 7, 2015 Report Posted January 7, 2015 If it's the one being sold at amazon for 120 then it's safe to say it'd nowhere near 3000 watts. If anything that's max watts which you will never see. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
