coh33dkill3r Posted January 9, 2015 Author Report Posted January 9, 2015 I wanna wire all 8 to 1 amp at 1ohm. Figure if 4 gave me 2 ohms I could wire all 8 series/parallel to achieve 1ohm....
coh33dkill3r Posted January 9, 2015 Author Report Posted January 9, 2015 Are you adding 4 more subs without adding power? Why not just run 2 amps? Want to only run 1 amp at 1ohm. Before I buy all my gear wanna make sure I'm getting the right config on the subs
Kyblack76 Posted January 9, 2015 Report Posted January 9, 2015 I like to use all outputs of the amp (when theres 2 (2 channels) wire 2 subs to 2ohm .. other subs to 2ohm use all 4 outputs, and youll see a final of one ohm with the internal wiring of the amp. I like using as much wire as i can..... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
coh33dkill3r Posted January 9, 2015 Author Report Posted January 9, 2015 Plan to use sundown scv-6000
Kyblack76 Posted January 9, 2015 Report Posted January 9, 2015 Plan to use sundown scv-6000 and? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
coh33dkill3r Posted January 9, 2015 Author Report Posted January 9, 2015 Don't think that amp has 4 outputs does it??
Jessica Posted January 9, 2015 Report Posted January 9, 2015 Kyle means 2 positive and 2 negative terminals so 4 total. He dosent mean the amp has 2 channels unless he is just being goofy tonight Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Kyblack76 Posted January 9, 2015 Report Posted January 9, 2015 Kyle means 2 positive and 2 negative terminals so 4 total. He dosent mean the amp has 2 channels unless he is just being goofy tonight werd... i like using all outputs using more wire...... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
