Wiring 8 dual 4ohm subs
8 DVC 4Ω subs does equal 1Ω
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
Are you adding 4 more subs without adding power?
Why not just run 2 amps?
2 sets of 4 wired to 2 ohm then the banks wired parallel to 1 ohm.
Not sure if it works like that, I've never wired 8 subs.
Wire the 4 subs in parallel to give you .5 ohms, wire the other 4 subs in parallel to give you .5 also, then wire both sets in series to give you a final load of 1 ohm.
http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=4&I=42#results
i dont' understand why you guys are making is so difficult with wiring groups and stuff. just wire each subs voice coils in series than put all the +'s and -'s to the amp
So you think all those wires will fit in the amps speaker terminals?
so wiring it in groups is going to change that?
Yes sir, only one set going into the amp instead of 8 like you proposed...a set as in 1 positive and 1 negative...
  • Who's Online   0 Members, 0 Anonymous, 4212 Guests (See full list)
