K_McPartlin Posted January 16, 2015 Report Posted January 16, 2015 I am building a new box for my jeep. I have 2 12 inch L5s and i have a normal ported box build with plans but i was wondering if a T-Line would be nicer. The only thing is i have no clue how to figure out the T-line math. I have read over 10 hours on it plus videos but i dont understand. Should i stick with a Normal ported box tuned to 30hz or should i make a t-line???? Normal ported Box(Used RE Box Calculator): Width=33 inch Height=17 inch Top and bottom Depth=17 Wood thickness=0.75 mdf Port Height=15 Port width=2.5 Port length 1=13.5 Port length 2= 9 Tuned Freguency= 30.179 hz I dont understand the T-line box math.
Triticum Agricolam Posted January 16, 2015 Report Posted January 16, 2015 What do you think a T-line is going to do for you that a ported box can't? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
SIDE SHOW Posted January 16, 2015 Report Posted January 16, 2015 go ported, L7'S and L5's seem to love ported boxes.... havn't seen one in a t-line
K_McPartlin Posted January 17, 2015 Author Report Posted January 17, 2015 Everyone says T-line are way better sound quality. I guess i stick with a Ported but when i upgrade or downgrade or my next build ill figure out a t-line
Pariah Posted January 17, 2015 Report Posted January 17, 2015 T line for 2 square 12 inch subs would be a massive enclosure. Just quick, 7.5ft line with an area of approximately 300sq in. Roughly the size of 4 of your current enclosures.
Triticum Agricolam Posted January 17, 2015 Report Posted January 17, 2015 Everyone says T-line are way better sound quality. I guess i stick with a Ported but when i upgrade or downgrade or my next build ill figure out a t-line T-lines can have excellent sound quality, if they are designed properly to do so. So can ported boxes though. T-lines can also sound like crap if they aren't done right, also like ported boxes. There is nothing about T-lines that automatically makes them sound better (or worse) than ported boxes. They are just a different way to do things that sometimes is better and sometimes is not. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
SQL50 Posted January 17, 2015 Report Posted January 17, 2015 I'd just go with a normal ported, slot or aero whichever you choose. Those subs like big boxes, being that it's square cone I would build the enclosure as If I was building for 15s. Btw don't use re, I've been down that road before. Wasted like $80 worth of wood, use Torres it's a lot closer.
