Charging system failing
At least the front. There is no magic solution, but its always better to have a better electrical than you need.
i would check the resting voltage of your current battery and check charging voltage of alt..and do big 3. Then go from there
Def do this first!
at under 13 volts im guessing that amps not even doing 1000...@2 could be wrong though...you for sure got something going on
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
For the big 3. You need to upgrade the positive wire from the battery to the alternator. The negatives from the battery to the chassis and engine block ground. Another that's beneficial is grounding the alternator case also.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
it is prolly only rated for that power at 14.4v. So you do likely have closer to 1000w.
XS are good batteries if thats what you decide. For sure do big 3 though there is a tutorial if you need one at the top of this forum
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
  • Who's Online   0 Members, 0 Anonymous, 2785 Guests (See full list)
