Charging system failing
i have never fused my alt...fuse for the wire i guess....someone im sure will chime in here or try the search button..
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
When it's just a regular wire. You just fuse to the wires amp rating. 1/0 is rated for 300/350. When you wire from a block to your amps, that's when you wire to what your amplifier is capable of.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
no. which one i get?
you fuse the amp to battery positive run with a fuse close to the amp rating of your alt.
Its only optional if your wire(s) clearly overestimate the max amperage of the alt. most people still fuse anyways though.
Yeah i purchased fuse blocks to do it when i bought my mechman alt..I just chose not to use them..I did however fuse between everything else though
2006 Dodge Ram 1500
Xs3400
1500BDCP
FI BL 12
3sq @ 32hz
Rockford t675
T400.2
Stinger Deadner
Build Log Here
  • Who's Online   0 Members, 0 Anonymous, 2785 Guests (See full list)
