Chris Dennis Posted January 22, 2015 Report Posted January 22, 2015 I want to build a box that will go in the back of my suburban. I have plenty of room to work with if needed. Max length of room in the back is 65", 45" wide and 20" tall. Of course we don't need to fill all that space, but if its what I have to do to get good deep sound out of these I don't mind using it all. I would like the box to be ported. Also would prefer that the subs face up towards the roof with the port facing towards the rear doors if you think that will sound the best. Can you design something like this for me please? I tried PMing you but it says you can't accept any new messages. Thanks in advance.
reedal Posted January 22, 2015 Report Posted January 22, 2015 He can't help if he doesn't know what subs you're using or the amount of power you'll be pushing them with. What kind of music do you listen to for tuning frequency? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Joe X Posted January 22, 2015 Report Posted January 22, 2015 Opened some space on PM try again or delete my screen name from the title and me and other can help you.
Chris Dennis Posted January 22, 2015 Author Report Posted January 22, 2015 sorry I had all that info in the original private message. I didnt realize it must not have copied over. They are two Sundown Audio Z v.2 18's Here is a link to their specs. http://www.sundownaudio.com/index.php/products/discontinued/item/z-series-v2.html I mainly listen to rap and like to listen to songs that get low. I want something that will get low as possible but still get very loud as well. I am planning on powering them with a SAZ 3500 or similar style amp running it at 1/2 an ohm.
Chris Dennis Posted January 23, 2015 Author Report Posted January 23, 2015 was kinda thinking a a box kinda like the one in this video.
Joe X Posted January 25, 2015 Report Posted January 25, 2015 A couple of things power @ 0.5 ohm on that amp and Xmax on the subs?
Chris Dennis Posted January 25, 2015 Author Report Posted January 25, 2015 actually, I am probably going to run the subs at 2 ohms just to be safe. I am not quite sure what amp I want to get yet, but I am looking at a stesom 3000 watt at 2 ohms amp or something similar. What happened to the sketch you had drawn. I swear I was on here earlier on my phone and saw a blueprint but now I cant find it
Joe X Posted January 26, 2015 Report Posted January 26, 2015 Get some amp that handles 0.5 ohm, is just that I would like to know what is the final power is going to be, also if you have the electrical to support 4K power or whatever you are going to run.
Chris Dennis Posted January 26, 2015 Author Report Posted January 26, 2015 I was told it would be better to run at 2 ohm load since it's my daily and it would be easier on my electrical. As of right now I am completely stock on the electric as of right now. I am thinking of getting something that will put out about 3,000 watts at 2 ohms. That way each sub sees 1500 watts which is what they are rated. I am thinking maybe audio pipe 3000.1 or kicker ax 2500.1 or the amp I listed two posts up. What do you think would be a good amp that puts out about 3000 k at 2 ohms and what electrical upgrades would I need?
Chris Dennis Posted January 26, 2015 Author Report Posted January 26, 2015 Also forgot to say if you think .5 ohm would be better let me know. I am new to all this so I need as much guidance as possible
