757lmj Posted January 27, 2015 Report Posted January 27, 2015 What kind of power do I need to run a soundqubed 3500?? It says 380 amps for the amplifier. 2 runs of 0 gauge + and -. What size alternator do I need?? And batteries??
757lmj Posted January 27, 2015 Author Report Posted January 27, 2015 I have a 96 blazer 4 door if that helps any
khinds94 Posted January 27, 2015 Report Posted January 27, 2015 200+ amp alt G34 under hood and 2 G31s in back. 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
757lmj Posted January 27, 2015 Author Report Posted January 27, 2015 Ok. I was leaning toward the 2 3100s. But how do I determine what alternator I need? Amp wise that is. I don't want any voltage drop Even when at a red light or just sitting
757lmj Posted January 27, 2015 Author Report Posted January 27, 2015 Xs batteries seem to be a bit more appealing. Also, I don't want to get a 220 amp alternator and come to find out I need a 300. Want everything done ritmghr the first time
khinds94 Posted January 27, 2015 Report Posted January 27, 2015 Xs batteries seem to be a bit more appealing. Also, I don't want to get a 220 amp alternator and come to find out I need a 300. Want everything done ritmghr the first time A 220 should do you fine if it does atleast 180 at idle. If you plan on upgrading power then buy a 300. Mechman DC Singer 03 Sable LS AA mayhem 12" D2 Sundown ZV4 12" D1 Tantric HD 12" D2 Tantric SHD 12" D1 Sundown X12 V2 D2 2.5 cu net Sundown 2000d @ 1 ohm XS Power XP2000 Sky High Sound Deadener Sky High wire Stock alt
Guest Posted January 27, 2015 Report Posted January 27, 2015 you want no voltage drop? two dc 270xp alts.
kirill007 Posted January 27, 2015 Report Posted January 27, 2015 you want no voltage drop? two dc 270xp alts. Overkill? 1 would be enough. Thinking is the root of all problems... You ALWAYS get what you pay for.
Guest Posted January 27, 2015 Report Posted January 27, 2015 you want no voltage drop? two dc 270xp alts. Overkill? 1 would be enough. he said 0 voltage drop
juan777 Posted January 27, 2015 Report Posted January 27, 2015 Buy biggest alt you can fit. This hobby is all about upgrading so plan ahead. The L@zy Hoe 2005 Chevy Tahoe 2,500 Watts of Highs/Mids 4 10 midrange 4 6.5 midwoofers 4 Tweeters 6 Supertweeters 2 Lithium 80AH Batteries 24K Watts 4 Custom 18s Quad alt setup Rebuilt 250amp and 3 370s Interior work by Lone Star Auto Works The Build Log Like Loud Bass? Click Here! On 12/5/2014 at 8:06 PM, juan777 said: See yall there, I'll be the drunk Mexican with aviators on. On 12/6/2014 at 10:32 PM, boom50cal said: I did see Juan LMFAO! He REALLY WAS the drunk mexican with Aviators on!
