help with swapping alternator wiring.!! ASAP
I'm swapping out my alternator as I'm typing this. The problem that I ran into is that the stock wire that went into the positive of the stalk alternator isn't fitting into the positive if the new alternator. How do I fix this?
is it the wire between the output stud on the alt and the positive terminal on the battery? if its not fitting go buy some 4 gauge or 1/0 and make a new one with the proper ring or whatever terminal it needs.
I have mine run straight from the alt to the battery.
But yes, you can run the new wire to the fusebox, but id also upgrade the wire from the fuse box to battery positive, if you do it that way.
SMD Super Seller
My Feedback Thread
  • Who's Online   0 Members, 0 Anonymous, 4212 Guests (See full list)
