Help with 3-way setup.
look at creative sound solutions they make two 4" drivers that are wideband with carbon fiber type cones. I would call them and ask about power handling though. Doesn't say in the literature.
http://www.creativesound.ca/details.php?model=VWR126X
http://www.creativesound.ca/details.php?model=WR125STR
The first one looks good, but its 8ohm :P
What's wrong with 8 ohms ??? Tweeters normally 6
There is nothing "wrong" with it, but I would like to maximize the power output. My tweets are 4ohm. The amp is 50watts is at 4ohms. 8ohm would roughly be half that. And I do not feel up for fiberglassing 2 8ohm drivers wired to 4ohm ohm per pillar either..
At what frequency is your amplifier rated at ?? 1000 htz ???
Sounds kinda ideal to me ...
Not running much more on mine, something like 75 wpc rated at 50 htz.
Um I'm not sure. How can you tell? Most of the amps I see listed are formatted like this:
  • RMS Power Rating:
    • 4 ohms: 50 watts x 4 chan.
    • 2 ohms: 75 watts x 4 chan.
<p>
  • RMS Power Rating:
You have a class AB amplifier ??
Don't be scared man up with a real amp :) So are you running two 4 channels?
I was hoping he would say 3 class AB 2 channels. But ............ ???
I was planning on two four channel amps. Both D. :P One for pillar and one for the 4 door speakers.
I am not not opposed to type AB, but I doubt I would be able to fit one underneath my seat. Plus, I do not like to worry about them overheating as much. I know that what i was planning isn't quite your recommendation Cableguy, I just have heard that class AB only sound nominally better. Idk, convince me if you think I should do otherwise! :)
  • Who's Online   0 Members, 0 Anonymous, 965 Guests (See full list)
