hdc3 true power handling
akaak
It's not my point of view, ask any engineer about impedance RISE, he won't know what you are talking about.
Impedance is just resistance + reactance.
Reactance is dependant on frequency.
If you plot the impedance: impedance in function of frequency, you will see there will be 2 peaks.
It's called the impedance response.
Did you read anything I posted? I clearly stated inductive reactance. The common word for this at least on the forum is box rise or impedance rise. But I'll do some research to see if I should start using impedance response instead if it is the official term used.
But thanks for the info. I explained it correctly but was using an incorrect term it sounds like but a common term to this forum.
That's the problem, people keep using the wrong terms.
well thanks for edumacating :)
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Should we also mention going from 1500 watts per sub to 3000 watts per sub will gain you 2-2.5 dB IF you are lucky? Why bother destroying things for such little gain unless you are really competing.
Pick up gain with the box design. . .
Black00 was doing 154+ on 4 15's that were $125 stamped frame woofers with a pair of amps rated at 500 watts (TL score, sealed on the dash, down into the mid 30 Hz range).
People seem to just worry about how much power can I run, and should I build a smaller box for less excursion or less impedance rise. . .crazy
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Good questions though OP, I'm curious myself.
I'm planning on 2 HDC3 12"s on my 4 antique Hifonics Brutus amps (flame on!!). So 4 x 1600 rms = @2k watts. lol
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
You know what OP, I respect that the fact you take a beating and keep on coming. Most noobs would be crying by now. I hope someone can help. I pretty much have the same shit as you and if I do upgrade the amps I'm gonna upgrade the subs too.
  • Who's Online   0 Members, 0 Anonymous, 879 Guests (See full list)
