So today I installed on a 2015 mustang some subs with the original 9 inch screen I noticed that while the doors are closed and you Rev up the engine you got a lot of exhaust noise into the subs I thought strange well to make a long story short there is a mic were the dome light is at that picks up on exhaust sounds and generates it through the speakers so obviously will using a convertor it will amp that sound as well if you come across this vehicle here is the tip remove the mic!
unplug it
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
Well you unplug the fuse and the stereo turns off too you unplug the mic and problem fixed first time installing in this vehicle so this is what I found out!
