Joe X Posted October 23, 2015 Report Posted October 23, 2015 So here it is but you are running too much power, tuning low is not going to help much, besides that low tuning may lose you some output. I would likely prefer the 33Hz one, let us know what you did and how it turned out for you.
beau123 Posted October 30, 2015 Author Report Posted October 30, 2015 So here it is but you are running too much power, tuning low is not going to help much, besides that low tuning may lose you some output. I would likely prefer the 33Hz one, let us know what you did and how it turned out for you. Thanks JoeX it's just like 150 watts more rated. it plays 4 ohms (1100 RMS) zx2500 manual says 1250 watts (RMS) at 14,4 volts with music loud it's around 12,2-13,2 Is that still too much? maybe i build both to just test a friend of mine is going to buy the xtreme version i can give one of the boxes to him.
CleanSierra Posted October 30, 2015 Report Posted October 30, 2015 Manufacturer is suggesting 2 4" ports per sub. Tuning that low will lose you output outer create a peaky box. I don't see the appeal to playing 24 Hz, I never will. Im not the one you want to try to troll. Just a fyi for you.
Joe X Posted October 30, 2015 Report Posted October 30, 2015 Thanks JoeX it's just like 150 watts more rated. it plays 4 ohms (1100 RMS) zx2500 manual says 1250 watts (RMS) at 14,4 volts with music loud it's around 12,2-13,2 Is that still too much? maybe i build both to just test a friend of mine is going to buy the xtreme version i can give one of the boxes to him. No it's ok @ 4 ohm, don't know if the extreme version is going to need different specs so bear in mind that. The other thing is that if you were running a 40Hz tuned box is not going to be amusing to loose output, that 28Hz tuning is only recommended if you almost only play slowed stuff and such.
