gladen sql 12 box
beau123
If you only want to check behavior of the sub you will need to enter the data on your link to modeling software and decide port area based on that, if you just want a layout done for you, you need to provide details on your application, vehicle..etc.
Application sql (must play rnb hiphop decaf)
Vehicle golf mk4
150 amp alternator
2 exxide ep450 batteries 1/0 gauge all around
Space is not really a issuebecause it cant be more then 80 liters for that sub
Tuned around 30hz
Vehicle golf mk4
150 amp alternator
Tuned around 30hz
So here is a suggestion for daily, everything firing back or up, you can test both, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 6.5 centimeters, figure is just an assembly guide:
  • 8 months later...
sorry been out of this a while.
Joe x is it possible to tune it lower?
that it can play 20 hz without bottoming out?
Are you wanting to play all the way to 20 Hz or just to the high 20's?
Builds:
Want to play decaf without bottoming out the box i have now is the standard box tuned around 40 hz.
so tune about 27 hz is okay i think (hope)
  • Who's Online   0 Members, 0 Anonymous, 3045 Guests (See full list)
