4th order port speed
Evagoras
Hi guys, im designing a 4th order box in winisd for two jbl's 12 inch, How much the vent mach should be?
2 4inch ports its 0.02
1 6 inch its 0.04
which one is best? thanks
Not enough information to tell if either option is sufficient :(
The more port area in a bandpass, typically the better.
they are the GTO1214, im using 1cu.ft sealed and 2cu.ft ported side, i like deep low bass, i tuned 50hz and it seems the best for me i think, i have them in a ported box now tuned to 32hz and im very pleased with the way they sound, on winisd they look that they have similar line wave on the graph but its 5db more, really is it that much louder 4th order?
the reason im switching into 4th order is because to much of the sound is getting lost in the trunk, ( my trunk is completely separate from cabin, its the chassis and fuel tank behind rear seats, mercedes 190E ) so with 4th order the ports are going to come out in rear deck and all the bass is going to be in the cabin, hopefully is going to sound better
5 db gain is pretty big. That's like almost quadrupling the output of the sub.
When you measured the vent Mach, did you put in the amount of watts you are going to run into WinISD?
Like CleanSierra said, more vent area is almost never bad, though as long as your vent Mach is below .05 (17 m/sec) you should be fine.
You aren't using the newest version of WinISD, you can get the newest one (0.7.0.900) from their Facebook page. https://www.facebook.com/WinISD
Builds:
i did put the rms power of subs in winisd, thank you, i will download the new version as well :)
by the way, im a bit concerned about the sound of 4th order, will i get similar output if i make a ported box with the port blowing in cabin and subs in trunk? whats your opinion on that ? thanks
The poet of a regular vented box resonates at a single frequency. I would not recommend a regular vented.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
  • Who's Online   0 Members, 0 Anonymous, 2846 Guests (See full list)
