what to use in corners of box
BigManAC
Okay, the less hassle the better. Im just trying to improve my score by a few decibles. Is there anything you recommend to do?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Rounding a port has its advantages. Rounding internal corners INSIDE the box is pretty useless is most cases.
When you say rounding the port do you mean leading to the outside?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Double post:
I can do a 144 but ive seen several people hit around a 46-48. Id be happy anywhere in between. I found the res fq of my car with a 8'' sub in a sealed box and its 37hz.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
I mean the port opening on the inside of the box(if it's a slot port). That's why aero ports are flared, it improves the efficiency of the vent GREATLY. You have both ends of your port rounded off if you care to get the most efficiency out of it as you can.
Okay ill try that out.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Fi recommends 12-16 so I planned on the 16 side and a small box at 3.5cuft. This is what I have so far.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
  • Who's Online   1 Member, 0 Anonymous, 1316 Guests (See full list)
