BigManAC Posted February 8, 2015 Report Posted February 8, 2015 I want to put curved edges in my box and was thinking about PVC but im not sure if the fiberglass will stick to it. How should I go about securing the PVC into the corners? 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
MrSkippyJ Posted February 8, 2015 Report Posted February 8, 2015 glue the pvc down then glass over them, the glass will adhere to the box over the pvc. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
BigManAC Posted February 8, 2015 Author Report Posted February 8, 2015 Okay thats what I was wondering. Thank you 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
n8ball2013 Posted February 8, 2015 Report Posted February 8, 2015 Or don't waste the time for no benefit THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
MrSkippyJ Posted February 8, 2015 Report Posted February 8, 2015 Or don't waste the time for no benefit there is that as well F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
BigManAC Posted February 8, 2015 Author Report Posted February 8, 2015 will it not make any difference at all? The box will be just for burps. I thought that the rounded corners helped with airflow or something? 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
MrSkippyJ Posted February 8, 2015 Report Posted February 8, 2015 it might, or it might not. If this was a daily set up I would say for sure skip it, but if you are chasing 1/10s then it might be worth testing. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
CleanSierra Posted February 8, 2015 Report Posted February 8, 2015 Air is not water, you don't have to make rounded corners or 45s. Im not the one you want to try to troll. Just a fyi for you.
thefourth Posted February 8, 2015 Report Posted February 8, 2015 Should the same answer apply to a kerfed box? If not, why? In for an answer Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
CleanSierra Posted February 8, 2015 Report Posted February 8, 2015 Rounding a port has its advantages. Rounding internal corners INSIDE the box is pretty useless is most cases. Im not the one you want to try to troll. Just a fyi for you.
