deathcards Posted February 12, 2015 Report Share Posted February 12, 2015 been giving me some problems finally not sure how to fix i am pretty sure my speaker has finally fried but gotta check resistance again after fixing the connections corrosion anyone that knows a lot about b2 could drop some knowledge to me please i have checked the fuses questions what is the x1 and the x20 switch for? solved does the protection circuit reset only after the ground has been disconnected? what is the TLA dial for? solved skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
Kyblack76 Posted February 12, 2015 Report Share Posted February 12, 2015 http://www.b2-audio.com/public_html/images/quattro_h_man.pdf edit- whats the problem? is it stuck in protect? or what? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
deathcards Posted February 12, 2015 Author Report Share Posted February 12, 2015 wow i must be half asleep srry yes stuck in protect have unhooked current components and put one into the first channel and right to protect it went i gotta still check the voltage it may be have a problem there but i am unsure and its dark so i am gonna tackle it tomorrow just looking for ideas i have unhooked the speakers and it comes out of it which pisses me off cause i put a good one in for sure unless the protection circuit thinks that since the sister channel doesn't have a load the its kicking the protection against overload gonna do some testing tomorrow skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
Kyblack76 Posted February 12, 2015 Report Share Posted February 12, 2015 wow i must be half asleep srry yes stuck in protect have unhooked current components and put one into the first channel and right to protect it went i gotta still check the voltage it may be have a problem there but i am unsure and its dark so i am gonna tackle it tomorrow just looking for ideas i have unhooked the speakers and it comes out of it which pisses me off cause i put a good one in for sure unless the protection circuit thinks that since the sister channel doesn't have a load the its kicking the protection against overload gonna do some testing tomorrow cool And i understand now. If you pull all load off the amp (the output/speakers) and the amp comes back from protect, then its the load (one of your comps, or speakers) Plug in one side of the load (speakers) and if it jumps to protect, that will show you which area to attack....... SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
deathcards Posted February 22, 2015 Author Report Share Posted February 22, 2015 well overall my problem is corrosion DON'T BUY CHEAP WIRE JUST TO GET YOU BY i got about 1 foot of corrosion from the front fuse heading towards the amp in the copper wire streetwires fml cheap ass, hard ass, pvc ass having jacket skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
deathcards Posted February 28, 2015 Author Report Share Posted February 28, 2015 well new news and some specs./measurements amp is still going to protect can't figure out why wires have been replaced (rcas, power, ground, remote) have tried to turn on with speakers unconnected and connected still goes into protect tried chanels 3 and 4 still protects things i know and have checked 3 times voltage 14.75v remote 14.75v ground less than .03 resistance components 4 ohms and 3.9 ohms running off channels 1 and 2 fuses good has never gotten hot on me plays for a second then goes to protect took this might help some gurus not sure amp off speakers unconnected all speaker channels 10ohms give or take a tenth will have more specs later getting late have an hour drive last day at current pt job or not cause i have a flat tire from a nail at 12:01am after a 1hr drive starting to think its dead gut pics sunday or saturday warranty was done a while ago skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps Link to comment Share on other sites More sharing options...
