Guest Brett32324
im guna be building a box for Four 12"s. it will be in a Grand Marqui (probably in the back seat but maybe in the trunk). the box is for two P2's and prolly 2 Infinitys. (if not itll be 2 Power Acoustiks.) each sub will have its own space to work with. wut should my measurements be.
and it actually sounded good. so dont say it cant. most of the time it doesnt, but mine did for some reason.
I said it's never a good idea..and i'm sticking with it. Glad you liked your setup...wouldnt reccomend it to anyone however...that's my point.
definitly a bad idea. But YOU can do it this way..... 2- tuned at 30hz and the other 2 tuned to 60hz, and use a common 45hz gain/boost and they should work together as a dual tuned band pass box- but definitly, they should Not play the same freq, 2 different subs work differently, move easier, or stiffer than the other, and will end up canceling eachother out at different freqs
But I assume 2- of one brand tuned at 60hz, the other 2 -30hz, should be okay sounding
  • Who's Online   0 Members, 0 Anonymous, 1365 Guests (See full list)
