6V 250Amp Hour Cells to use or not to use for Car Audio?
The capacity (AH) of a series chain of batteries will match that of the lowest capacity in the chain.
Therefore two 250AH batteries in series will still be 250AH overall since the current through both batteries is the same. Voltage is additive.
There is confusion with capacitors in series. In that case, the capacitance is halved with two identical caps in series.
Two 6V batteries will work fine in series, but as with other power components in series, you'll want to keep an eye on the voltage of each battery.
Probly not a huge deal with two batteries, but there is potential if one battery goes bad and induces more voltage on the remaining battery.
There is where cell balancing comes into effect with series caps.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
beat me to the thread. good explanation.
yea the biggest part is confusion between battery cells and cap cells here.
when you start to series any kind of cells, balancing becomes a factor.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
That's where I got messed up. Only done equations with caps. Never death with batteries for capacity and amperage draws.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
i have a 300amp alternator :) im sure that would be okay? - i wont be banging it none stop like i used to :) its more for comps and shows :) 30 second average for meter etc... and then maybe 10 mins for the crowd etc :)
"So yes. Each set is 125AH. Total of 375AH. Amperage rating you'd have to find. I think amperage stays the same in series"
this is confusing... is the AH(amp per hour) not the same as amperage per hour? to me it is...
AH (Amp Hours) is a good idea of capacity, it's meant to be a recharge rate. It will take 250 amps to recharge in 1 hour from somewhere. I forget what point that is. I was asking on the amperage rating. Like you have a 300amp alt. What are the batteries capable of taking for a draw. 600A? 1000? Who knows? That's what some were getting at. If they aren't rated for much u may have problems when the time comes.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
