jmanjr82 Posted March 4, 2015 Report Posted March 4, 2015 Here is the gathered information for my usable area: Height: 20 Width: 33 Depth: 20 Subs: 2 Skar ZVX 12s (http://www.skaraudio.com/skar-audio-zvx-12v2.html) Amp: Taramps 8k wired at 1ohm Looking at 34hz tuning as recommended. I listen to all kinds of music but lean towards Decaf, EDM, Rock such as FFDP Any help would be greatly appreciated.
jmanjr82 Posted March 4, 2015 Author Report Posted March 4, 2015 Honda S-MX https://images.search.yahoo.com/search/images;_ylt=AwrSbDhuBvdUxJ8AEztXNyoA;_ylu=X3oDMTExbGtvMmJiBGNvbG8DZ3ExBHBvcwMxBHZ0aWQDVUlDMV8xBHNlYwNzYw--?p=Honda+Smx&fr=yfp-t-901
jmanjr82 Posted March 7, 2015 Author Report Posted March 7, 2015 If there is anything further you need from me to aid in getting the design finished ask and I will get it asap.
Joe X Posted March 8, 2015 Report Posted March 8, 2015 So here is a suggestion, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 4 3/4", figure is just an assembly guide, bracing is 1 1/2" wooden dowel rods:
jmanjr82 Posted March 9, 2015 Author Report Posted March 9, 2015 Looks good Joe X thanks for the input I will get this box built asap and give results! Only question I have is you said "minimum port clearance 4.75" what do you mean by that? In the diagram it shows the subs and port firing up correct?
Joe X Posted March 9, 2015 Report Posted March 9, 2015 Everything up, yes, clearance spec is just informative.
jmanjr82 Posted March 9, 2015 Author Report Posted March 9, 2015 ok awesome thank you for the clarification. What are the chances of doing a subs up port back port in the middle style box ?
Joe X Posted March 9, 2015 Report Posted March 9, 2015 Not very good on those dimensions, specially depth, if you had some more (like 7" or so) maybe it would have gone that way.
jmanjr82 Posted March 10, 2015 Author Report Posted March 10, 2015 OK I will remeasure and come up with another spot for my rear battery and amps. If we go that deep, can we cut down the depth some?
