Aq2200 getting power but not producing power
garton05
The amp is a AQ2200 brand new. Been sitting on it for years. Brand new kinetic 3800 battery in the back. The bass control knob up from is lighting up and power to the remote. Also power going in on the positive side but nothing coming out. Messed with all the gains and everything still nothing. No fuses that are external. Someone has to know what the heck is going on. Alpine Iva-w205 head unit
1998 Pontiac bonneville SE
Alpine Iva-w205 touchscreen.
Phoenix Gold Titanium Elite 12
AQ2200 amp
Kinetik HC 3800 battery
Big 3
did you check the master/slave switch?
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Check to make sure its not in slave and on master
edit: ninja'd OP. that happens to me everytime I take my amp out and put it back in
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Yea flipped it back and forth. Gets stiff when I take it off slave
AQ2200 amp
Big 3
My ground off my amp has to be good or it wouldn't have power to it right?
AQ2200 amp
Big 3
In your sig you have two Q2200's. Are both hooked up in your car and strapped?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
It would still power on even if it was getting some type of ground but if its not a strong ground your amp will protect as soon as a load is put on it and its stressed.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
I just changed rigs so I only have one amp and sub. Well the grounds gotta be good because it not protecting its self. Could the rear battery be so low it's not producing?
AQ2200 amp
Big 3
could be an rca problem
power: dd m4
  • Who's Online   0 Members, 0 Anonymous, 1134 Guests (See full list)
