2013 sonata sundown build 4th order wall
Box was knocked loose plus wiring needed to be redone and score sucked. ...back to drawing board 4 dd9515,,,4 tantric shd15...or what else? ??? Dc and sundown are sold out for a good bit :(
  • 1 month later...
take RGB led strips and hot glue them to the outside baskets of the PWX's with the leds facing IN... the woven cones are see though, you can light up all your speakers. like i did in the pics below and see video here: https://www.youtube.com/watch?v=_ky9uSdq6Qw keep in mind i made this video for a guy that was going to buy these off me. and room was a mess from doing lots of projects.
that is so freaking cool dude i think i got a few blue strips of leds... but idk if mine will work mine are more of straight lines i guess they could be cut tho huh?
well you can buy a 5 meter strip of RGB leds from amazon for like 20 bucks... get 2 or 3 strips, wire them up to a single controller and there you go.
edit: http://www.amazon.com/SUPERNIGHT-Waterproof-300LEDs-Flexible-Controller/dp/B00B2F3KDQ/ref=sr_1_1?ie=UTF8&qid=1432276318&sr=8-1&keywords=rgb+led+strip under 16 bucks each... 3 of these. cut a strip long enough to go around each speakers basket. hot glue it or zip tie. solder connections to EACH speaker so you can remove each speaker with out bothering the others, then run the wires to a master teminal and that to the included controller, runs right off 12v so just tap it in to you power with a 10A fuse... bam bam you got fancy lights that you can change to any color or effect you want... i have these installed in my house as well for the main lights, over 1200 single LEDs instead of 2 bulbs. same power draw as 2-60w bulbs, but i have NO shadows in my room and its MUCH brighter.
Gonna be loud, all these SCV 6000 got me jealous!
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
  • Who's Online   0 Members, 0 Anonymous, 1544 Guests (See full list)
