Mitsu Crew Cab - 4th Order Wall, Kiwi Style
that is awesome, and genius with the "window", that is truly sick
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
Thanks guys. Still got a long ass way to go, but having fun and learning a lot!
That is rad as hell......
I want a crew cab mini !!!!!!!
Lol, I get that a lot on the American sites! They're common as hell down here - Toyota, Nissan and Mazda all do crew cabs. You still pay good money for the 'yotas, but everything else is reasonably cheap.
Man... id kill for a CREW CAB mini......they are non exsistant here.......... im dreaming of a 6th order already....
I wish you luck with your build...
Thanks man, I appreciate it. I think Mexico got D21 Hardbodies in the crewcab option? Not sure what the importing laws are around that, but could be worth looking in to?
As the saying goes - you need power to make power, so next up is the electrical system. As I mentioned, audio gear here is crazy expensive - I'm looking at $600NZD for a 170a Mechman, which just isn't in the budget for the time being, so I had to think outside of the box. The stock alternator puts out a whopping 45amps which is barely enough to support a head unit, let alone a 3000w+ stereo system, so I sourced a 120amp alt off a late model Mitsubishi sedan. The mounting tabs were different to the stock alt, so had to get creative with the mill.
Stock on the left, 120a alt on the right.
2012-10-08_13-18-30_20.jpg2012-10-08_18-04-07_575.jpg2013-07-20_13-52-32_262_zps84246a1d-1.jp
All done
2013-07-20_13-52-53_470_zpsac2efc70-1.jp
  • 3 weeks later...
Well I spend 10 hours over Easter Sunday on this heap and still feels like I didn't get a lot done. All the little shit that you don't really see takes so damn long!
Any way, both baffles are now glued in - bottom one is 30mm and the top is 18mm. Combined with the bracing and right angle steel, this thing is solid as fuck!
Spent a bit of time filling some of the pocket holes with reinforced filler as some of them poked out from under the recessed baffle.
I've used 5mm threaded inserts so I can bolt the subs in rather than just screwing them in to the wood (this alone took over an hour - 32 pilot holes follwed by 32 6.5mm holes and then screwing in 32 inserts....glad I'm not doing that again!). Will make servicing/changing out subs much easier though.
