Mitsu Crew Cab - 4th Order Wall, Kiwi Style
Here's a little build I've got going on down here in New Zealand. The truck is a crew cab Mitsubishi L200 (same as Mighty Max). It's been my daily driver/on-going project for the last 10 years, so it's seen it's fair share of system changes over the years.
After tossing around all sorts of ideas, I've decided it's time to bite the bullet and wall it. It was always heading that way, so may as well get it over and done with. Go big or go home right?
The system is fairly tame compared to some of the builds on here. Gear down this way is crazy expensive due to shipping and I've got a family and mortgage to think of as well!
Pioneer 80PRS
Highs: Image Dynamics Ultra HLCD's on mini bodies on an Audiomedia ADP1000.2
Mids: Crossfire XS-M8's on an Audiomedia ADP2000.4 (bridged)
Lows: 4) Crossfire C5 12 D2's on a Sundown SAZ-3000d
Sub enclosure is a 4th order bandpass - rougly 2.5:1 ratio, I want to measure the sealed side's peak before finalising the vented side, but I guessing it'll somewhere in the high 40's.
On to the build:
I'd previously build custom door panels for dual 6.5" mids, but obviously they wouldn't work for the 8" mids, so they got sold and I've started new ones. First of all though, the doors got the heavy sound deadening treatment.
I stripped the Peel'n'Seal off...don't believe everything you read on the net!
I started with a set of Massive Audio CK6 components, so started the door panels to suit those, and changed to the XS-M8's later
DSC05783_zpsfc50ba1f.jpgDSC05787_zps1ce6db80.jpgDSC05801_zpsb1574ad7.jpgDSC05822_zps731b34c0.jpg
Baffles for the XS-M8's are made from 25mm HDPE - solid as F'k and will never swell from moisture! Makes a bit of a mess when milling though!
IMG_20150104_151419_zpsycxgulw5.jpgIMG_20150110_110935_zpsscx2rgm5.jpgIMG_20150110_125732_zpskwgg5az5.jpgIMG_20150209_144246_zpsyfknicrd.jpg
Another reason NOT to use Peel'n'Seal - this shit is a pain in the ass to clean once it starts falling off :angry2:
Mitsubishi kind of dropped the ball with factory deadening, but at least gave me a nice blank slate to work with!
10947231_10155202509955492_5699893054309
With deadening out of the way, it was time to start the fun stuff. I started off with the base, which is 1-1/4" of layered MDF, then 1-1/8" ply on top of the rear seat riser and bolted in place using the seat mounting holes. The shell is all 1-1/8" ply. Sealed section will just be single layer with 1" bracing, 1" x 1/8" right angle perimeter and sealed with resin. Ported side will get an additional layer of 3/4" ply for a total of 1-7/8". Should be sweet yeah? I can always add steel bracing if need be.
Baffle is also 1-7/8" thick, and sits on top of all the bracing.
Added a window on the rear wall to try a keep a degree of practicality while walling a daily driver :rolleyes: I'm using 20mm acrylic to fill the hole.
^^Which is about as far as I am right now. HUGE props to all you guys doing crazy builds - it definitely isn't a walk in the park!
looks awesome!!
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Damn man I love it! You do some really nice work, so clean too. Tuned in, keep the pics. coming
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Glad to see someone else using horns, nice build so far.
Nav-TV Zen V Audio Interface
AudioControl DM-608
(2) Stevens Audio Neo-Comp Full-Size Horns
(4) Faital Pro 6PR160 6.5"
AudioControl LC-6.1200
(1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz
Ampere Audio AA3800.1
Odyssey ODP-AGM48 Battery (Starting)
Odyssey ODX-AGM31 Battery (Trunk)
Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs
Thanks guys. Still got a long ass way to go, but having fun and learning a lot!
That is rad as hell......
I want a crew cab mini !!!!!!!
Lol, I get that a lot on the American sites! They're common as hell down here - Toyota, Nissan and Mazda all do crew cabs. You still pay good money for the 'yotas, but everything else is reasonably cheap.
I've had them sitting on the shelf for ages but kept putting off installing them 'coz they're such a mission to install. Drivers side isn't going to be too hard, but I need to take about 1.5" out of the heater bower unit to make the passenger side to fit. I've always been more of an SQ guy, but the SQ scene here is pretty much dead, so figured I'd build something that will impress the bassheads, but still stage and image nicely. I'm a little worried the XS-M8's won't have the midbass I'm looking for, but I'm thinking of trying ported door enclosures if they don't perform free-air in the doors like they are now.
