Need help!! Enclosure opinions
Doing a trunk build for a friend and he has a MAX of 39.5W x 17.5H x 34D... He's given me the ok to do whatever I want with this space... I was thinking 2 12" in a 4th order but don't know too much about them.... Maybe just a ported box with 2 15s..... What's everyone's opinions on what I should do with the available space.... Any help would be appreciated
If you dont know much about 4th's, dont bother, it may end up as a complete flop if one calculation is off. I wont even touch a 4th design, i dont know nearly enough about them to even attempt it. if you max your box size your gross volume is 11.44 cubes using 3/4" material, seems like a lot for a trunk to be honest considering my box for my suburban is 8.8 cubes gross for 4 10s, but its lots of space to work with for something cool if thats correct.. You are going to need to provide a little more information though. Whats your desired tuning? What power level? Does that 11.44 cubes need to house batteries and what not as well? sealed off trunk and front facing?
-If its loud, fast, outrageous, or all of the above, chances are i'll think its awesome.
-"No way he's OCD." -said none of the people that know me ever.
04' Suburban "Lucifer" A.K.A #Lucii (Under Construction)
4 10s on 4kW in 6cu net @~28hz
/////Alpine
Crescendo
KnuKoncepts
Optima
SHCA
Build Thread
92' JDM 325i "Stella" ~Going for sale to build a 350+hp E30~
Gutted pipes
96,000 OG KM's (59,000 mi)
-System Removed-
1 10 on 1kW
89' Gen 3 Honda Prelude SI AWS "Odis"
Bone Stock
Possibly going to stance it
He wants it to be musical... Not chasing numbers... Trunk will be sealed off.. Power is a 3.5k... Possibly a 5k if I can talk him into it.. And yes the numbers are correct. That's my max dimensions. Don't have to use all that but can if need be.. I wouldn't have a problem building a 4th order If someone could help design it for me..
If you find someone to design you a good 4th order, you will probably be paying for it, im sure someone that's been around longer then I have could recommend someone to you but i know off the top of my head Ram Designs seems to do pretty darn good work. your best best is probably 2 high end 12s (perhaps 2 DC XL 12s on 5k would do some work) tuned around 35hz, probably one of the better musical setups you can do as high powered 12s are VERY versatile and will leave you some room to make an efficient box as opposed to cramming more cone area into a trunk and ending up with something peaky and inefficient. With the leftover room you could make a nice clean amp rack, and even house a battery or two. Just my opinion though, if you so desire, 15s will work.
/////Alpine
Crescendo
KnuKoncepts
Optima
SHCA
Build Thread
Gutted pipes
-System Removed-
1 10 on 1kW
Bone Stock
No offense man, but if you don't know much about 4th order bandpass boxes (ported boxes are 4th order designs too BTW) why do think you want one for your friend? There is a lot of info floating around about bandpass boxes and not all (or even most) of it is accurate. They aren't black magic that will mysteriously make you system 10 db louder, or provide perfect flat frequency response. Bandpass boxes have specific advantages, but those don't apply to 99% of car audio applications.
If you are looking for system that is reasonable musical and decently loud a ported box designed to meet those goals will almost certainly be your best bet.
Builds:
Pretty sure that a couple of very cool 15s will get you awesome performance ported, sealed off.
  • Who's Online   0 Members, 0 Anonymous, 4815 Guests (See full list)
