if its showing signal, and picking up the 40hz and 1khz track, and your volume is on max, it maybe that your headunit is distortion free at max volume.
Several headunits are.
The volume is only at 45 out of 62... I was setting my gain at 45 because at 48 it "sounds" like its distorting on the 40hz track.
:crazy:
EDIT- and what track are you using to find HU noise ?
Track 1
Dude... your fucking lost....
Read your manual.
If you want to find where your HU makes noise at... you need to play both the 40hz tone and the 1k.
Dude.. read that lil white paper that came with that THINGY you bought... This is not rocket science. ..
I am reading it lol, I've read it over and over again. I do everything it says, don't get any signal light or anything even when maxed out. This is the case only when I'm just trying to see where my head unit distorts.
Did you run BOTH tracks ?
EDIT- if you dont get a SIGNAL.. then something is not right... period.
Only tried the 40hz track because I don't get a signal light so why bother with the 1khz track. What could be wrong then?
:crazy:
Track 1
Read your manual.
Coming right off the deck RCAs ? or are you look from the amp ?
If off the deck, what RCA's did you use ? the sub out ?... are all RCA's open/full ?
Edited by Kyblack76
:crazy:
Track 1
Read your manual.
This is through the amp. Straight from the RCA's I still get nothing.
RCA's are knukonceptz Krystal. Yes sub out. Open or full?
Edited by SundownZ71
:crazy:
Track 1
Read your manual.
through the amp.... why not do just the deck ?
  • Who's Online   0 Members, 0 Anonymous, 1200 Guests (See full list)
