sundownaudio Posted March 22, 2015 Report Posted March 22, 2015 Need Box design help for Subs: (2) DD9915 powered by aAMP:Taramp's T-10k @ 1ohms 3200rms each Vehicle:Toyota Hilux Surf (Lots of space) Building Material: 3/4" Plywood Thank you in advance for assistance.
Triticum Agricolam Posted March 22, 2015 Report Posted March 22, 2015 If 3/4" MDF isn't available can you get 3/4" plywood of some kind? Some plywoods are better than others but with the power you are going to be running and the size of the box I would not want to use 5/8" material. Not to say it couldn't be done, but you would have to double or triple up the material in places and brace the tar out of it. It would be a lot of work. I'd use 3/4" OSB if you had to even. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
sundownaudio Posted March 22, 2015 Author Report Posted March 22, 2015 If 3/4" MDF isn't available can you get 3/4" plywood of some kind? Some plywoods are better than others but with the power you are going to be running and the size of the box I would not want to use 5/8" material. Not to say it couldn't be done, but you would have to double or triple up the material in places and brace the tar out of it. It would be a lot of work. I'd use 3/4" OSB if you had to even. let me re-edit, 3/4" plywood available (7 plies) would that be suffice ?
Triticum Agricolam Posted March 22, 2015 Report Posted March 22, 2015 Yup, 7-ply 3/4" plywood would be fine. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
sundownaudio Posted March 22, 2015 Author Report Posted March 22, 2015 Yes, Post max dims for a box. well Joe, i have W45" H25" D35"
Joe X Posted March 22, 2015 Report Posted March 22, 2015 Here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 9 1/4", figure is just an assembly guide:
sundownaudio Posted March 23, 2015 Author Report Posted March 23, 2015 Here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 9 1/4", figure is just an assembly guide: thank you very much Joex uoure always a great helper
