Need design for 2 SQ HDS212's
Skyfall
Hi guys,
Looking for a ported box design for 2 SoundQubed hds212 gonna be running 600-700rms per sub. (If i have room ill go with the 15" aka hds215) The main music I listen to is rap, trap, dubstep, anything with bass. Done buying prefab crap boxes.
Space that i can work with
Hight 17
Width 39
Depth 28
Hds212 info
Piston Diameter 254.0 mm Mounting Depth 6.5" Circle Cutout 11.1875" Outer Diameter 12 7/8 with gasket Xmax 26.5mm Peak to Peak Magnet Weight 100oz f(s) 39.03 Hz Q(ms) 5.367 Q(es) 0.587 Q(ts) 0.529 V(as) 29.700 liters
(1.409 cubic feet)
Hds215 info
Piston Diameter 330.2 mm Mounting Depth 7.5" Circle Cutout 14" Overall Diameter 15 3/4 with gasket Xmax 26.5mm Peak to Peak Magnet Weight 100oz f(s) 36.34 Hz Q(ms) 7.483 Q(es) 0.895 Q(ts) 0.800 V(as) 73.310 liters
(2.589 cubic feet)
box size and tuning info http://www.soundqubed.com/Box-Sizes-and-Tuning-_ep_68.html
Ok, what's the vehicle?
Good lord Joe, They should pay you full time plus some for the work you do around here hahaha Sorry for the tread jack but my gosh you do some high quality work on here!
-If its loud, fast, outrageous, or all of the above, chances are i'll think its awesome.
-"No way he's OCD." -said none of the people that know me ever.
04' Suburban "Lucifer" A.K.A #Lucii (Under Construction)
4 10s on 4kW in 6cu net @~28hz
/////Alpine
Crescendo
KnuKoncepts
Optima
SHCA
Build Thread
92' JDM 325i "Stella" ~Going for sale to build a 350+hp E30~
Gutted pipes
96,000 OG KM's (59,000 mi)
-System Removed-
1 10 on 1kW
89' Gen 3 Honda Prelude SI AWS "Odis"
Bone Stock
Possibly going to stance it
2000 Buick lesabre, seats don't fold down only has the arm rest hole
Here is a suggestion for the 12s, subs / port back, rear deck open / partially open is recommended, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 5 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 574 Guests (See full list)
