Flip_one Posted March 24, 2015 Report Posted March 24, 2015 This is my first time building a box for my 15" L7s, I want the box to have one big port on the right side and I wanted tuned to about 32hz-35hz. I'm looking for really deep bass and the most SPL out of that box. Can anyone help me? I need the exact measurements for each piece of wood to make the best box for these subs. It will be going into my 2001 Chevy Tahoe. Thanks!!
Joe X Posted March 25, 2015 Report Posted March 25, 2015 So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5 1/4", figure is just an assembly guide: NOTE: Please verify the suggested dimensions will work in your vehicle and that the port clearance to the rear gate is met once the box is in.
Flip_one Posted March 25, 2015 Author Report Posted March 25, 2015 Thanks Joe! I kind of want the subs and the port both facing the rear tailgate, I think it sounds better that way. Is there any way to have the subs facing back and the port next to them?
diegoclass2010 Posted March 25, 2015 Report Posted March 25, 2015 subs up port back will play better/louder in your tahoe. just check to see if the box joe x designed fits, any way you havent really given out the max dimensions you can spare for the box, or how much power you are giving the subs
Joe X Posted March 25, 2015 Report Posted March 25, 2015 Ok if you want it like that here it is, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 7 3/8", figure is just an assembly guide, bracing is 1 1/2" wooden dowel rods: NOTE: Please verify the suggested dimensions will work in your vehicle and that the port clearance to the rear gate is met once the box is in.
ZAPCO209 Posted March 25, 2015 Report Posted March 25, 2015 X2 on subs up port to the rear, will sound better and louder. THE DRIVING FORCE
Joe X Posted March 31, 2015 Report Posted March 31, 2015 Will this box work on l7 12s No, you would need one for 12s, if you make a thread I could make you one.
