running power to amp from battery 2013 altima
Yes drill through the firewall. Once you get over that fear things become much easier.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Or run it under the car and drill a hole in the trunk. Either way.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
and buy a grommet to seal hole and protect you wire
or you can go ghetto run it to the floor board where your feet go there are allways rubber drain plugs you can use to run wires remove drain plug done
  • Who's Online   0 Members, 0 Anonymous, 3413 Guests (See full list)
