Low preout voltage?
Or you could run the rear outputs in full range and split it to both amps with a y cable, or daisy chain the amps if one of them has a line out.
I've reset it numerous times. I think the front RCA has voltage output its just between 0 and 0.1 and my dmm won't detect it. With the amp maxed out on the front RCA it reads around 5 volts at the speakers on each channel which is around 6 watts at 4 ohms. So 6 watts per channel lol
LOL, yeah righto. can to borrow or use another deck to test it out? you don't wanna go buy a new deck to find out that the deck isn't the issue tis all. but by the sounds of it, you have a dicky deck
