Hey guys when I got my box made for my two 15s the guy wired them up series parallel. So instead of having all four wires in my amp I only have two would it be better to wire all four of the wires since I bought a bigger amp? Amp I had when o got the box made was a 750 watt prime and I upgraded to a 1200 watt prime
Are the subs dual 1 or dual 2? The positive terminals probably tie together on the inside of the amp as well as the negatives. If your looking for louder, the wiring will depend on if your amp is one ohm capable.
@mrskippyj they are the stinger speaker wire ATM I don't know what size can find out.@ PDub I believe there dual 2ohm. What I wanted to know is would it make any difference having then wired with 2 wires or all four
I would also make sure the impedance on the sub. Depending on that you may or may not need 4 wires going to the amp
  • Who's Online   0 Members, 0 Anonymous, 3434 Guests (See full list)
